Kuka
Handles handling and spot welding
The 'KR Fortec' from Kuka is an energy-efficient and dynamic heavy-duty robot that can be used in particular for tasks such as handling and spot welding.
© Kuka
Technically, the industrial robot from Kuka is positioned between the 'KR Quantec' and 'KR Fortec ultra'. It is also available with an extended arm, allowing loads of 240 kg to be handled over a reach of 3700 mm. The two central hands have been adopted from the 'KR Quantec' and 'KR Fortec ultra' models and are waterproof and dustproof as standard. The 'KR Fortec' can be operated at 0 to 55°C. Several foundry versions are available for harsh and dirty environments. The working range of the robot can be extended with the 'KL 4000' linear unit - modularly adaptable between 1.5 m and 30 m. The 'KR Quantec' also fits on this linear unit. To work with the 'KR Fortec ultra' on the same linear unit, users choose the 'KL 5000'.
Kuka
Cobot assistant for SMEs
A user-friendly cobot application for small and medium-sized companies that can be used without programming - a team of researchers from Belgium received the Kuka Innovation Award 2024 for this concept.
Kuka
Cobot in quality assurance
The 'Ligre' brand is conquering the consumer sector with the function of grinding coffee to the exact gram, which was previously reserved for coffee machines for the catering trade. Gronbach relied on Cobot support in the test setup for quality...
Kuka
Most read
The top articles in March 2024
New technological developments lead the most-read articles in March. Motors that redefine energy saving, a plastic wheel that discovers the road, a new Ecolabel and, last but not least, the arrival of ChatGPT in the industry. Read for yourself.
