Congatec
Cooled with heat pipe
Congatec presents a new 100 W ecosystem for embedded edge and micro servers. The computing core is a COM Express Type 7 Server-on-Module with 65 to 100 W power.
The modules can be equipped with heatspreaders and heatpipe adapters.
© Congatec
These recently introduced conga-B7E3 modules are equipped with processors from the 'AMD EPYC Embedded 3000' series, which contain up to 16 cores with a maximum TDP of 100 watts. According to Congatec, these world's first 100 W server-on-modules in COM Express Basic format (95 mm × 125 m) can be equipped with heatspreaders and heatpipe adapters, which ensure efficient heatpipe cooling even in extremely flat 1U servers.
By dispensing with rotating fans, the servers are very robust and are suitable for applications in the IoT, Industry 4.0 and edge environment.
You will find Congatec in Hall 1, Stand 358
© NurembergFair
Peak system
Data exchange via CAN FD
The I/O module PCAN-MicroMod FD from Peak-System is now also available with ready-made motherboards in a black aluminum profile housing in addition to its use as a plug-in module in in-house developments.
compmall
Slot CPU for many operating systems
ISA and PC/104 are sought-after standards in the industrial PC sector. The ISA slot CPU in half-size format VDX3-6724 from Comp-Mall has a PC/104 slot and can therefore be supplemented with measurement and control cards in ISA format via backplane...
