Displays
Quelle: Mitsubishi | Lukas Dehling,
Vibration resistance of 6.8 G
MSC Technologies has expanded its product range with three TFT LC modules from Mitsubishi. The industrial displays have a vibration resistance of 6.8 G and are designed for operation in a temperature range from -40 °C to +85 °C.
© Mitsubishi
At the same time, all models offer a brightness of 1500 cd/m² and a contrast ratio of 700:1 for readability even in bright environments. The service life of the LED backlight is specified as 100,000 hours. The TFT Dìsplay AT070MJ11 in TN technology has a WVGA resolution with 800 x 480 pixels and a screen diameter of 17.78 cm (7.0 inches). The viewing angle is 140 degrees vertically and 160 degrees horizontally. The panel has an LVDS interface. The active area is 152.4 x 91.44 mm, the dimensions of the LC module are 169.8 x 109.7 x 8.9 mm. The 26.42 cm (10.4 inch) TFT display AT104SN11 offers an SVGA resolution of 800 x 600 pixels. The viewing angle is specified as 160 degrees (symmetrical). This LC module is also equipped with an LVDS 6/8 bit interface. The display area is 211.2 x 158.4 mm. The AT104XH11 LC module with XGA resolution (1024 x 768) also has a diameter of 26.42 cm (10.4 inches). The display surface of all three Mitsubishi products has an anti-glare film and a 3H hard coating.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
