Scanner
Quelle: Opticon Sensoren GmbH | Lukas Dehling,
Only 15.4 mm high
Opticon offers the FDI-4100 2D imager, which, according to the manufacturer, can be integrated into POS systems, PDAs, data collectors, terminals and ticket machines thanks to its design with a height of just 15.4 mm.
© Opticon sensors
The imager reads 1D and 2D barcodes as well as OCR-B text. It can be used in applications such as access control, time recording and price checkers. Green and white LEDs and the new high-speed decoder make it easy to read any barcode - regardless of the barcode quality or surface properties (display, paper, tickets). The 2D imager is said to offer good reading properties thanks to a CMOS area imager and 100 fps. In addition, an 800 MHz processor supports decoding. When configuring the scanner, "Data Editing" supports the reading of up to 16 codes at once, as well as "GS1" for editing the scanned data in the defined format. The module has RS232C, USB and micro-USB interfaces.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
