Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
Browser-based programming is possible with the web HMI construction kit Spidercontrol from Ininet. On the right-hand side of the tool there is a theme catalog, in the lower area the objects of the selected theme are displayed and described if necessary. The user can insert these into their current page from here. Within the page, the various objects can also be moved and resized or parameterized. In this way, all elements of the Web HMI Editor can be used and combined to suit the individual customer. All components of the Web HMI Editor are drawn using the PC-based editor. Each desired object is graphically designed and grouped on the PC, and the parameters required for configuration in the Web HMI are marked. The selected parameters then appear in the Web HMI Editor as properties of the object and can be easily adjusted by the user in the field.
