Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
4 of 17
Transflective display in small format, available from SE Spezial-Electronic.
© SE Spezial-Electronic
The industrial TFT WF0283ATDAJDNN0 with a 2.83 inch (7.19 cm) display from Winstar, which is offered by SE Spezial-Electronic, is suitable for indoor and outdoor use in very bright environments. The display with a resolution of 240 x 320 pixels is based on transflective display technology. As the ambient light contributes to the display with this technology, the display is still very easy to read even in direct sunlight without particularly bright backlighting, according to the provider. If the brightness is sufficient, the backlight can even be switched off completely. In contrast to conventional transmissive displays, the contrast also increases with increasing brightness. A backlight with a luminance of up to 500 cd/m² is available for operation at low brightness. The display, which is equipped with a TFT driver HX8367-A with internal frame buffer, is controlled via a parallel 8/16-bit microcontroller, a serial 3-/4-wire or a 9/18-bit RGB interface. The typical operating voltage for the TFT is 2.8 V, whereby the IO level can vary between 1.65 V and 3.3 V. The LED voltage of the backlight is specified as typically 3 V.
4 of 17
