Jumo
Inka Krischke | Tiffany Dinges,
Reliable transmission of switching signals
The two-channel Ex-i isolating switching amplifier from Jumo was specially developed for the float switches of the 'Nesos' series, but also supports all proximity sensors according to the NAMUR standard.
© Jumo
The intrinsically safe isolating switching amplifier complements the supplier 's safety performance portfolio (JSP) and ensures reliable, galvanic 3-way isolation and safe transmission of switching signals in both normal and Ex applications. It can be used in the extended ambient temperature range from -40 to +60 °C, has ATEX and IECEx approval and can also be installed in Ex zone 2.
The connected float switch contact or proximity sensor can be operated up to zone 0. In addition, the Ex-i isolating switching amplifier has UL and DNV-GL approval and meets SIL 2 in safety-related applications. Line fault detection detects line breaks or short circuits and ensures process reliability. Thanks to the integration of two channels in one device, the Ex-i isolating switching amplifier requires very little space during installation. Coded screw terminals and simple configuration with DIP switches save time during commissioning. LEDs indicate the respective status directly on the device.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Jumo
Continuously measured
Safety PLCs are not always necessary to implement safety requirements in tank systems. In some cases, the use of safety monitors or limiters is also sufficient.
Jumo
Supplemented by three modules
The Varitron automation system from Jumo is being extended by three modules: The 32-channel digital I/O module offers 32 channels, 17 of which are configured as digital outputs as standard.
Jumo
Use in hazardous areas
Especially in chemical or process engineering processes, additional heating is required to maintain or increase the temperature in order to optimize the complex processes of modern industrial plants. But what needs to be considered here?
Three questions for ...
Trends in robotics
Under the title "Three questions for ...", computer-automation.de is publishing short interviews with the leading figures in the automation industry on a regular basis this year. This month, the focus is on robotics.
