Product presentationsNews from measurement technology
What innovations are there for industrial users on the measurement technology market? Computer&AUTOMATION has summarized a selection of new products in a series of pictures
The Precont PU4SE from ACS-Control-System is an electronic, programmable 2-wire pressure sensor for monitoring relative pressures in gases, vapors, liquids and dusts. The module can be calibrated and programmed via HART communication - calibration via RS485 Modbus RTU is also available as an option. The measuring range extends from 1 to 600 bar at process temperatures from -25 °C to +100 °C with an accuracy of 0.5 %. According to the manufacturer, robustness and long-term stable and reliable measurement are guaranteed by the ceramic internal diaphragm and the IP69K protection class. The pressure sensor has standard industrial process connections. A captive laser marking on the nameplate is intended to ensure identifiability over the entire service life of the device. A LABS-free or silicone-free version, factory calibration with calibration certificate and a customer-specific configuration or presetting are also available as options, as is a material test certificate EN10204 3.1.
