KistlerData management from development to production
Solutions for collecting, managing and evaluating measurement data from Kistler can be demonstrated using the example of the "Smart Single Stations": The modular assembly and test systems help users to carry out process steps with high precision and check product quality.
ifm offers intelligent power supply units that provide the required voltage directly on site. The power supply units comply with protection class IP67 and can be installed together with other components on the machine or system. Integrated electronic fuses in the power supply units protect the 24 V power supply against overvoltages and short circuits. The output voltages and rated currents of the individual circuits, for example, can be set via the IO-Link interface of the power supply units. Current values for voltages and currents of the individual circuits, input voltage, operating hours, internal temperature, etc. can be read out via IO-Link. The power supply units are available in two versions with a three-phase or single-phase power supply on the input side. The three-phase device has four output circuits whose maximum current can be set to up to 12 A. The single-phase device has two output circuits with up to 4 A each. The rated outputs are 500 W and 300 W respectively.
SPS 2022: Hall 7A, Stand 302
