Product picture galleryNews from the software sector
The IT sector is playing an increasingly important role in automation. As a result, the demand for software in companies is also increasing. Computer&AUTOMATION presents the latest product innovations in this segment in a series of pictures.
The latest version of Rockwell Automation's Factorytalk batch software promises improved operation through a modern web-based interface, while being more scalable and providing responsive phasing of distributed process skids, centrally coordinated at the shop floor level. Integration with Rockwell Automation's SequenceManager solution means that sequencing is performed at either the controller or server level. This enables machine builders to develop fully tested skids that end customers can integrate into their batch processes with minimal validation effort and short commissioning times. It should also reduce the amount of rework required when manufacturers with small, controller-based batch systems want to upgrade to larger server-based batch systems. The new web-based interface can help to create intuitive workflows, reduce process steps and improve collaboration. With mobile devices, employees no longer need to be directly connected to the control center and fixed terminals. They can access information in real time, interact with processes and obtain plant-wide production approvals. It should also reduce the number of clicks previously required to access information.
