Process modules
Quelle: Copa-Data Deutschland,
Flexible modular system
Shorter time-to-market is playing an increasingly important role in the process industry and this must be mapped early on in the product life cycle.
© Copa-Data Germany
Together with Merck, Copa-Data is presenting a pioneering approach for use in the laboratory to meet these challenges: A plant is made up of several autonomous plant modules. A module is digitally mapped to a specific process step, an automation component or the entire system. The smaller the modules, the more flexible the system. According to the 'modular principle', systems can be reassembled from the individual modules again and again as required. A large part of the engineering already takes place in module engineering. Finished modules can be used as often as required. MTP (Module Type Package) is a standardized description of the process engineering aspects of a system module and is the interface between process and automation technology. This is an official and manufacturer-independent standard (VDI/VDE/NAMUR 2658). As soon as the individual MTPs are imported into the control system at a higher automation level, all functions are automatically made available there and orchestrated from there. Copa-Data will be demonstrating the integration of MTPs and orchestration for use in the laboratory environment with Merck at the SPS using a current project as an example.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
