Codesys Group
Safety controls implemented more quickly
The Platform Support Package (PSP) for Service Pack 16 of 'Codesys V3.5' accelerates implementation.
The ability to run security applications in parallel on one CPU is part of the Platform Support Package.
© 3S
According to Codesys, the safety extensions for the 'Aurix TC29x' microcontroller from Infineon, which is popular in the field of mobile machinery, have been taken to a significantly higher implementation level. The entire runtime environment (runtime system) for the 'Aurix' platform has already been adapted and pre-certified in advance - including the interfaces for specific extensions or drivers from device manufacturers. This eliminates a large part of the work involved in implementing the runtime environment and its certification. ECUs and safety controllers implemented in this way are therefore ready for the market much faster.
Thanks to the multi-core architecture of the microcontroller, functional and safety applications can also be executed in parallel on one CPU (compound PLC).
The system optionally supports CANopen or CANopen Safety as a safe fieldbus - corresponding devices can also be configured and used together in a network.
Codesys
From data analysis to OPC UA PubSub
With the Codesys Automation Server, Codesys added an Industry 4.0 platform to its IEC 61131-3 automation software last year. The latest innovations for this platform and a library for OPC UA-PubSub communication will now be presented at SPS Connect.
SICK
Simple implementation of IO-Link devices
How can the integration of IO-Link devices into control systems be simplified? An open software-based service for all IO-Link device manufacturers automatically creates function blocks and thus significantly reduces the implementation effort.
