Light+Building 2018
Davina Spohn,
Integration of KNX in Codesys
The industrial standard tool Codesys now supports KNX, one of the most important fieldbus systems in building automation. The integration can be seen for the first time at the Light+Building 2018 trade fair.
Graphic for the integration of KNX in Codesys
© 3S-Smart Software Solutions
Codesys is a well-known and manufacturer-independent development system in industrial automation according to the international standard IEC 61131-3. The software is already used thousands of times in building automation - in particular to intelligently control temperature, lighting and room climate and thus exploit savings and optimization potential.
The KNX integration in Codesys was specified and developed in cooperation with ABB. The product range now being presented at Light+Building 2018 consists of a configurator for I/O channels, a KNXnet/IP protocol stack in the form of a runtime system component and a data exchange function with the ETS5 configuration system. This should allow any Codesys-compatible device to be expanded so that it can function as a KNX participant and communicate with KNX I/Os.
The integrated data channels of the Codesys controller are simply and completely transferred to ETS5 and generate corresponding "associations" in the Codesys runtime system. The input and output data integrated in this way can be provided with an intelligent logic function in Codesys. At the same time, users can transfer the data to other bus protocols such as BACnet or OPC UA. Thanks to the Industry 4.0 properties of the tool, building automation can be networked with SmartFactory or SmartEnergy systems.
Codesys at Light+Building: Hall 9.1 / Stand D71
ABB at Light+Building: Hall 8 / Stand F50/G50
Light+Building 2018
The "smart everyday life"
"Connected - Safe - Convenient" is the guiding theme of Light+Building 2018, and the trade fair for lighting and building technology will kick off in Frankfurt from March 18 to 23 with new focal themes, a new special show and an additional hall...
Big plans for 2018
The Kempten-based company 3S-Smart Software Solutions, manufacturer of the IEC 61131-3 automation software Codesys, increased its turnover by over 6% in 2017. A major event - the Codesys Technology Day - is coming up in May this year.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
