Mechanical and plant engineeringControl and regulate in the tightest of spaces
Austrian manufacturer Binder+Co has integrated almost 900 high-speed valves into its latest generation of machines for sorting used glass. As space is at a premium here, the blow-out valves and their controls had to be extremely compact.
<p>Thanks to the high packing density of the control and I/O system, significantly more valves can be installed without having to enlarge the control cabinet. There is space for up to 20 channels on a width of 12.5 mm, a height of 104 mm and a depth of 72 mm.</p> © Binder+Co
