Raspberry Pi, Arduino & Co.Tech gadgets under the Christmas tree
Christmas time - a time to relax and immerse yourself in technical gadgets. Computer&AUTOMATION has put together some experimental kits and practical books that are also suitable as Christmas presents.
6 of 15
Arduino UNO board
© Franzis Verlag
... Arduino Uno board, a microcontroller board based on an ATmega328. The board has 14 digital inputs/outputs (6 of which can be used as PWM channels), 6 analog inputs, a 16 MHz quartz, USB interface, a 6-pin ISP connector and a reset button. It contains everything you need to get started and can be easily connected to the PC with a USB cable or operated via a power supply unit or battery.
6 of 15
