Raspberry Pi, Arduino & Co.Tech gadgets under the Christmas tree
Christmas time - a time to relax and immerse yourself in technical gadgets. Computer&AUTOMATION has put together some experimental kits and practical books that are also suitable as Christmas presents.
14 of 15
Programming microcontroller learning package from Franzis
© Franzis Verlag
This Franzis learning package contains a microcontroller system on a universal control board, 25 components and an 80-page manual with over 20 experiments for a quick and easy introduction to microcontroller programming. Simple control programs can be created effortlessly: The "key-programmable controller" (TPS) gets by with easy-to-learn commands that can be programmed into the controller using keys. The program can be changed at any time and without any special tools. The system is particularly suitable for compact applications in electronics, where it can be used to perform many tasks to full effect. After successful programming, you can integrate the microcontroller into your own circuits. The enclosed manual guides you from the simple component to the finished project without a lot of theoretical ballast.
14 of 15
