SPS IPC Drives 2016New products in Nuremberg
What new products did the exhibitors present at SPS IPC Drives 2016? Computer&AUTOMATION provides an overview of what was on show in the Nuremberg exhibition halls this year.
9 of 65
EDS440 insulation fault locator from Bender
© Bender
The EDS440 insulation fault locator from Bender is specially adapted to the additional functionality of the 'iso685' insulation monitoring device. The 'iso685-D-P' variant is equipped with the locating current injector required for insulation fault location and the operating menu for setting the EDS440 has been extended and adapted. An automatic bus scan for detecting the connected insulation fault locators and individual text input for the alarm messages make it easy for the operating personnel to use. The connection is made using plug-in terminals, which are available either as screw or spring terminals. The device series basically comprises four variants: EDS440-S and EDS440-L for use in main circuits with a response value for the generated test current of 2 to 10 mA as well as EDS441-S and EDS441-L for use in control circuits with a response value for the generated test current of 0.2 to 1 mA.
9 of 65
