Logistics systemsNew products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of images.
The fully automated, ultra-flat Fast Move transport robot from E&K Automation is available in different versions. In the standard version, the robot moves pallets from cantilever to cantilever. With another load handling device, a lifting table with a stroke of 140 mm, it transports a trolley from A to B. Equipped with a customized special body, i.e. with two load handling attachments in one vehicle, the transport robot is able to pick up and return KLT crates from roller conveyors at two different heights. The scalable transport platforms are compact - the smallest version is 130 mm flat, 600 mm narrow and 1400 mm short. They are flexible, require no maneuvering space and, thanks to their stepless and low-maintenance drive concept, can carry out any movement in the area. The largest version has a load capacity of up to 2000 kg.
