Euchner at the SPS 2022Key system for many applications
The "CKS2" key system from Euchner can be used for locking machines and systems, for assigning authorizations, for selecting an operating mode or as a key transfer system.
Kontron presents the KBox R-101 with EN 50155 certification and 5G connectivity. The control and communication platform in box PC format is based on a fanless, passively cooled and IP54-compliant system solution with industry-approved mechanical and electronic components. The system and all external interfaces are suitable for use in harsh industrial environments and public transportation. Based on the eleventh-generation Intel Core i7-1185GRE processor and a maximum memory expansion of 32 GB, the platform supports OEM manufacturers and system integrators in setting up system solutions. On the front, it has three Gigabit Ethernet interfaces M-12 x-coded, two serial I/Os and a USB-C interface. There are also six cut-outs for antenna connections as well as seven LEDs, which can be used for specific applications, and a power LED. The system is designed for operation in a temperature range between -40 and +70 °C.
SPS 2022: Hall 7, Stand 193
