Current productsInnovations from the Control & Drives division
Control & Drives - i.e. controllers and intelligent drives - are the core components of automation technology. Computer&AUTOMATION shows an excerpt of current products from these areas in a picture gallery.
There is an automation solution from Lenze for next-generation storage and retrieval machines (SRMs) that consists of intelligent hardware and software: A motion controller acts as the central point for controlling the travel and lifting drive as well as the axes of the load handling device. The machine module for stacker cranes from the 'Lenze Fast Application Software Toolbox', which controls all the functions of the stacker crane, is integrated. Intuitive user guidance via GUI (Graphical User Interface) and a prepared visualization of the storage and retrieval machine facilitate engineering. In addition, the integrated online identification of payloads allows the pre-control of the servo controllers to be automatically and dynamically adapted to the constantly changing loads during operation of the SRM. The purely software-based control technology reduces the mast vibrations remaining after feedforward control by means of counter-pulses, which enables high acceleration of the travel drive without time-consuming S-grinding. With a special power failure control system for the drives, the drives are stopped in a controlled manner without the mechanical brake being applied immediately. A power failure is detected in less than 5 ms, possible energy consumers are switched off and the travel drive is switched to regenerative operation. This makes it possible to utilize the kinetic energy of the stacker crane and store it in the intermediate circuit of the servo inverter until the stacker crane has dissipated its kinetic energy. Only then do the brakes apply.
