operator terminals:
Quelle: Pilz | Inka Krischke,
Control the entire system process
Pilz offers the PMI 6 Control (Pilz Machine Interface) product range, an operator terminal equipped with a soft PLC to IEC 61131-3 standard.
© Mushroom
In addition to diagnostics and visualization, the entire system process can be controlled in just one device. The operating terminal is based on a processor module with 1.3 GHz. Together with 512 MB RAM and 512 MB flash memory capacity and the Windows Embedded Compact 7 operating system, this creates a platform for all applications. The devices are equipped with a capacitive glass touchscreen in 7 inch or alternatively 12 inch, which can be operated intuitively. In addition to the user-friendly visualization according to the manufacturer, any common HMI software can be used for visualization thanks to open interfaces. Software packages can be easily installed with the help of the 'PMI' wizard. It is part of the supplied SD card and can be easily called up if required.
Safe automation
Generational change at Pilz
Pilz exceeded the 300 million euro sales mark for the first time in 2016. 2017 is characterized by a generational change: At the end of the year, Renate Pilz will hand over the operational business completely into the hands of her children Susanne...
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
