Embedded PCs
With Skylake CPU
Comp-Mall presents the fanless emebedded computers from Cincoze with Skylake CPUs. The compact DI-1000 model (185x165x54 mm) is based on the Intel i5-6300U dual-core CPU and the DX-1000 model is based on the Skylake i5/i7 quad-core processor, both with DDR4 SO-DIMM memory.
According to the manufacturer, the number and variety of interfaces make the models particularly suitable for applications in automation, monitoring, environmental monitoring and use in vehicles. The basic configuration includes 6x USB, 4x COM, 2x GbE, 4x DIO, DVI-I, DP and audio. Two full-size mini PCIe slots can be used for expansions, for example for WiFi, GSM, WWAN. With the P2000 model, a PC module with Intel i5-6300U dual-core processor and DDR4 SO-DIMM up to 32 GByte is now available. The P2000 model can be used with existing monitors from the CV series or with new Panel PCs in 12, 15, 17 and 19-inch sizes. The DA-1000 model is designed as a cost-effective variant and for simpler applications. This fanless embedded computer is based on the Intel Atom E3826 dual-core processor with up to 4 GByte DDR3L SO-DIMM.
