Industrial server
Quelle: MSC Technologies | Lukas Dehling,
Six slots for system expansions
MSC Technologies presents the 4U 19-inch industrial server Infinity S4-408-MBC612, which is based on an ATX board with Intel Xeon E5 processors and the Intel chipset C612. For very high requirements, the server can even be equipped with two Xeon E5 processors with up to ...
© MSC Technologies
... can be equipped with up to twelve cores. The industrial system can operate in a temperature range between 0 and +45 °C; depending on the configuration, operation up to +50 °C is also possible. Two 92 mm fans are mounted at the front and a 60 mm fan at the rear to dissipate the heat. The ATX board has 2 × 4 DIMM sockets for fast DDR4 memory (2133/1866/1600 MHz). A maximum memory capacity of 256 GB per CPU can be fitted. Typical areas of application for the rugged server system are image processing and real-time analysis as well as the evaluation of extensive measurement data. The server is equipped with drives for accommodating 2.5-inch SSDs, 2.5-inch and 3.5-inch HDDs, 5.25-inch DVD-RW (slimline) or DVD-RW in a RAID array. The industrial computer also has two 5.25-inch bays and an internal 2.5-inch bay. A total of six free slots are available for system expansions. The scope of delivery includes a 500 W power supply unit - 100 to 240 V(AC) - and the system is available with a redundant 2 × 500 W power supply unit or with a DC power supply unit on request.
Advantech
Develop edge servers efficiently
The design of industrial servers is demanding. Industrial server manufacturers have therefore created an ecosystem for OEMs and system integrators that covers the range from robust standard configurations at board and system level through to...
Dell Technologies
Edge computing links IT and OT
However, neither the cloud nor a centralized data center are suitable for processing the volumes of data generated by the Internet of Things. Edge computing is taking the place of traditional approaches, but has its own unique challenges.
TTTech
The PLC in the data center
What are the advantages of using an integrated, centralized control architecture on an edge server instead of a large number of individual controllers with their own electronics? Only used in isolated cases today, such an architecture could become...
