Schubert System Electronics
Advertorial | Tiffany Dinges,
Prime Cube - Computer technology "Made in Germany"
High-performance, reliable and compact in a slim PICO design or with plenty of power as a PERFORMANCE platform, the Prime Cube boxes and panel IPCs are developed and qualified for 24/7 use in industrial digitalization and automation solutions.
© Schubert System Electronics
With Prime Cube - a wide range of applications and a safe investment
The PICO and PERFORMANCE platforms enable a wide range of applications. The Prime Panels are available as surface-mounted and built-in versions and in diagonals between 10.1" and 21.5". As a touch monitor and a solution that can be placed up to 100m away, they are the ideal complement to the Prime Box IPCs.
Industrial Box PCs - Prime Box Pico and Prime Box Performance
At the core of the PICO platform is an Intel ATOM x7-E3950 processor; an ideal basis for many applications. The PERFORMANCE systems offer computing power for complex tasks with Intel iCore processors of the 8th and 9th generation. They can be expanded easily and in a variety of ways via PCIe slots.
All components meet the highest quality standards and are verified and validated for industrial use.
Due to the functional and performance reserves, future tasks can also be solved. Prime Cube systems are therefore a safe investment in the future.
The systems can be freely configured with many options and offer a wide range of connectivity in the BASE version. The portfolio is being continuously expanded. If requirements go beyond the BASE standard, the STYLE configuration offers a selection of customer-specific customization options at a fixed price. More in-depth system adaptations or individual system development are possible with the CUSTOM version.
The consistently robust system design follows the principle of "form follows function" and is underlined by a high-quality aluminum housing. The purely passive, fanless system and processor cooling contributes to high reliability and operational safety. The Prime Cube systems can be used in a temperature range from -10°C to +50°C without any problems.
All Prime Cube products are available for 10 years and come with a 36-month warranty.
Prime software as an essential building block
Industrial panel PCs with multi-touch for the visualization of industrial applications can be implemented as built-in and surface-mounted variants.
The software is a central component of an industrial application. For all Prime Cube computer systems, we offer the 64-bit operating systems Windows 10 IoT Enterprise and Linux in a proprietary Debian 10 distribution.
The operating systems are kept lean and resource-saving and are optimized for use on the Prime Cube IPC platforms.
For the best possible time-to-market of your application, the configuration levels BASE, STYLE and CUSTOM also apply here. In the BASE configuration level, the operating systems form a solid basis and therefore a quick and easy-to-integrate standard for your solution.
A specifically configured UEFI and operating system is available for your optimal work preparation. With the STYLE version, individual default settings such as user configuration, the definition of passwords or even a system boot with your logo can be implemented easily and at a fixed price. Linux can be quickly expanded at this level with the integration of stable Debian, Prime Cube or customer packages.
The CUSTOM configuration level offers an efficient overall solution. Here, customer-specific software developments are implemented according to your requirements. CUSTOM enables optimal adaptation to your requirements through software integration, comprehensive UEFI and operating system adaptations according to customer requirements or individual software development. Especially for Linux, we also offer you complete package development, LINUX kernel customization and individually adapted Linux operating systems based on buildroot.
All operating systems are archived with their configuration on our internal servers and are only changed and managed at our location.
Customized development - everything under one roof
Prime Panel touch monitors are the perfect complement to our Prime Box IPC
In addition to our standard products, we also implement your customer-specific development of electronic assemblies through to complete systems. From the development, verification and validation of your solution to stable series production, everything is united under one roof at Schubert System Elektronik.
Our application and system engineers support you throughout the entire development process - from the initial idea to series production.
The embedded software for hardware-related software development and the system software for industrial computer technology cover the entire spectrum of necessary know-how.
In addition to expertise in x86 and ARM-based designs, electronics development also offers solutions in FPGA design, high-speed design and power electronics.
The design department draws on a broad knowledge of a wide range of materials and manufacturing processes. A contemporary device design, high-quality surface finishing processes and sealing systems up to IP69K are no challenge.
Verification and validation accompanies the development process right from the start with electromagnetic tests, temperature and IP tests as well as shock and vibration tests. With our compliance management, we develop the optimum approval strategy for UL, CE, RED, CCC, ATEX and many others.
Excellence in industrial interaction
Visit Schubert System Elektronik from 21.06. - 23.06.2022 at the embedded world 2022 in Nuremberg, booth 219, hall 5
Schubert System Elektronik stands for more than 50 years of development experience in the field of industrial computer systems - from sensors to the cloud, from hardware and software to assemblies and complete systems. The company develops and produces with around 170 employees in Neuhausen ob Eck near Tuttlingen. As part of the Gerhard Schubert Group, SSE is a globally active family business.
Find out more at www.schubert-system-elektronik.de
Schubert System Elektronik GmbH
take-off Gewerbepark 36
D-78579 Neuhausen ob Eck
Phone: +49 (0)7467 / 9497-0
E-mail: [email protected]
Follow Schubert System Elektronik also in the social networks
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
