Compmall
Power via 8th generation Intel CPUs
For complex software and ever more data, Compmall offers the hardware with the GH-1000 embedded PC with whiskey-lake power.
Embedded PC GH-1000 with increased performance and less space requirement.
© Comp-Mall
For the high-end version of the GH-1000, Intel Xeon or Core i7 with six cores and 12 MByte cache provide the power. The DDR4 memory can be expanded up to 32 GB. If the performance of the Intel UHD graphics card is not enough, you can upgrade via MXM. The GH-1000 supports USB 3.1 and optional 10 GbE LAN. An NVMe SSD can be controlled via M.2 Key M 2280 and M.2 Key E 2230 enables the integration of an Intel CNVi module.
The CompMalls CS series of CS-100/P2102 Panel PCs increases performance in a smaller space with the new P2102 PC module. The model with the 8th Gen. Intel Core i5 CPU offers the latest USB 3.1 Gen. 2 in addition to standards such as RS232/422/485, isolated DIO, GbE, DisplayPort and VGA.
With 9th Gen. Intel Core i9, the IMBA-Q370 ATX mainboard achieves maximum computing power. The DDR4 memory with 2666 MHz supports up to 64 GB. The mainboard offers interfaces including USB 3.1 Gen. 2 and Gen. 1, RS232 and for displays VGA, HDMI and DisplayPort++ with a resolution of up to 4K.
Dynabook
Wearables in the industry
Trend topics such as big data, AI and IoT are currently much discussed in companies. They are intended to optimize work processes and ensure greater flexibility. Assisted reality (AR) and virtual reality (VR) play a central role in this context.
