Mini PCs
Quelle: Shuttle | Lukas Dehling,
Play 4K content
The 141 mm × 141 mm × 29 mm NS02A and NS02E computers from Shuttle do not require a fan and run with a power consumption of just 4 W.
© Shuttle
In addition to a soldered 'Rockchip-RK3368 Octa-Core Cortex-A53 64-bit processor', both models have 2 GB of DDR3L RAM and 16 GB of flash memory. The internal 2.5-inch drive bay with the separately available PHD5 mounting frame can be expanded with an SSD or hard disk. Both models are based on the reliable and widely used Android 5.1.1 (Lollipop) operating system. The two models differ in one key aspect - the NS02E does not require a power supply unit and draws power directly from the network via PoE (Power-over-Ethernet), into which it is integrated. NS02A, on the other hand, is supplied with power conventionally via an external power supply unit. Both models have HDMI 2.0, USB 2.0, Gigabit Ethernet with WOL, audio and Kensington Lock on the rear. WLAN and Bluetooth are also on board. A memory card reader is part of the front section and rounds it off with two USB ports. Playback of 4K content (3840 × 2160 pixels) is possible at 60 Hz thanks to the PowerVR SGX6110 graphics processor and HDMI 2.0.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
