Product presentationsNews from the industrial computer sector
What's new on the market for industrial PCs and operating systems? Our picture gallery shows you the latest products from these areas.
Kontron's Embedded Box PC family has been expanded with the KBox B-201-CFL. Thanks to eighth-generation Intel Core i3/i5/i7 processors and the Intel H310 Express chipset, the box PC can handle computing-intensive processes and large amounts of data, for example in high-end image processing or production data acquisition. The 'KBox' is certified to EN55032 Class B and therefore complies with stricter radio interference limits than Class A. The core of the computer is a motherboard in the Mini-ITX form factor (170 mm x 170 mm) and a CPU with up to six processor cores. Various mounting options ensure flexibility: using a VESA mount, the Embedded Box PC can be operated directly behind a monitor or as a desktop PC horizontally or vertically. Special brackets are available for mounting under the table, on the wall or in the control cabinet. The compact housing, measuring 190 mm x 60 mm x 190 mm, is made of hot-dip galvanized sheet steel (EN10215) and aluminium. The box PC can be operated at ambient temperatures from 0 to 45 °C. The system has a DisplayPort V1.2, which can be used to operate up to four displays, as well as a DVI-D connection. Storage media for the operating system and data can be accommodated in the 2.5 inch SSD SATA III/SATA-600 removable drive or in an internal M.2 SSD (2280, 2260, 2242) slot. The box PC runs on the Windows 10 IoT Enterprise LTSB operating system and on Yocto for Linux.
