New productsNews from the industrial computer sector
What's new in industrial PCs? Our picture gallery shows you the latest products in this area - from conventional embedded devices to USB hubs and specially enhanced Raspberry Pi devices.
With the new Box-PC model Tank-870e-H110, Comp-Mall offers a fan-free system for mounting in a cabinet, on the wall or in a vehicle. The system is specially designed for applications in the field of machine control and automation technology. According to the manufacturer, the computer is largely vibration and shock resistant thanks to its robust design and complies with MIL-Std-810G. It can therefore also be used as a control unit in vehicles. The model is available in three variants with 1× PCIe x16, 2× PCI or 1× PCIe x16, 1× PCIe x4, 1× PCI or 3× PCI slots. There is also 1× full-size PCIe Mini slot and 1× full-size PCIe Mini slot with mSATA. The box PC is available with the Intel Core i7-6700TE (2.4 GHz, quad-core) or Intel Core i5-6500TE (2.3 GHz, quad-core), Intel H110 chipset and two 260-pin sockets for DDR4 SO-DIMM up to 32 GB. Two independent display outputs and other interfaces are available: VGA, HDMI, 2× PCIe-GbE-LAN, 4× USB-3.0, 2× isolated RS422/485, audio, 2× PCIe-Mini. The system operates at temperatures from -20 to +50 °C. Its dimensions are 255 mm × 190 mm × 133 mm.
