New productsNews from the industrial computer sector
What's new in industrial PCs? Our picture gallery shows you the latest products in this area - from conventional embedded devices to USB hubs and specially enhanced Raspberry Pi devices.
The Fujitsu D3474-B Thin Mini-ITX motherboard from the Extended Lifecycle series is designed for continuous operation at temperatures up to +50 °C. According to the manufacturer, this makes the motherboard suitable for tasks in semi-industrial applications such as digital signage, 1U solutions, HMIs or touch panels. However, the mainboard is also suitable for all-in-one PCs (AiO), so-called 'tiny box' PCs and systems with a flat design. It has a CPU socket in the LGA1151 series and supports processors with a TDP of up to 65 W. This includes models from the Intel Core i3, i5 and i7 series of the 6th generation and the current 7th generation. The board can also be equipped with Intel processors from the Pentium and Celeron series. The integrated H110 Express chip set supports up to 32 GByte DDR4-2400 SDRAM. Power is supplied via 12 V(DC) or 19 to 24 V(DC). Hard disks or solid state drives (SSDs) can be connected via SATA III interfaces. An M.2 SSD interface (SATA) is also available for SSDs. Users can also integrate wireless LAN and Bluetooth modules via an M.2 slot. A Gigabit Ethernet port is available for connection to wired networks. There are also interfaces for USB and serial devices with RS232 as well as an 8-bit GPIO port (General Purpose Input/Output).
