Box PCs
Quelle: Plug-In Electronic | Lukas Dehling,
For up to 7 HD displays
Plug-IN presents its latest Embedded Box PC series BP-ECS9700-GTX950/BP-ECS9600-GTX950 with the new Nvidia graphics processor GeForce-GTX-950, whose Pascal architecture enables the control of up to 7 independent HD displays or 6 independent Ultra HD 4K displays.
© Plug-In Electronic
The series is equipped with the Intel Xeon Core processor (Skylake-H) and the Intel CM236 chipset and can accommodate up to 32GByte ECC memory with the dual-channel DDR4-2133MHz.
Multiple SATA-III (6GPs), USB 3.0 (5Gbps), PoE (1Gbps) LAN and wireless connections enable data transfer. The computer systems can be used in an extended temperature range of -40° degrees to +60° degrees. A power supply from 10V to 36 V DC with 80V overvoltage protection should also ensure reliable use in a wide range of applications.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
