Motherboards
Quelle: congatec | Lukas Dehling,
For performance-intensive graphics applications
One feature of the Conga-IGX motherboards from Congatec is the configurable TDP of the processors, which allows the cooling and power supply design and system costs to be optimized for specific applications.
© Congatec
The boards are primarily used in applications that require high-performance graphics for low-power devices. The new boards with the second generation of AMD's Embedded G-Series SoC processors are available in a 2.2 GHz dual-core design or as a multiprocessing optimized 4x 1.2 GHz quad-core platform. With the integrated Radeon R5E/R3E next-generation graphics core from AMD, the boards offer 4k graphics support including DirectX11.1 and OpenGL 4.2. Up to two displays can be controlled independently of each other via DisplayPort 1.2, DVI or LVDS. They also support OpenCL 1.2. The boards can be expanded via a PCIe x4 Gen 2.0 slot, 1x MiniPCIe, 2x USB 3.0 and 6x USB 2.0. Via a special socket, applications can also be easily and cost-effectively expanded using standard USB sticks with, for example, WLAN, mobile connectivity or security mechanisms (dongle). For IoT networking, the boards run 2x Gigabit LAN.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
