Spectra
Yvonne Junginger,
Embedded board for automation solutions
The 3.5" embedded board LE-37P7 from Spectra is equipped with the Intel Core i7-11850H processor from the Tiger Lake generation.
© Spectra
The processor is supported by DDR4 memory, which can be expanded up to 32 GB. Mass storage devices can be integrated via two SATA ports. The integrated Intel UHD high-performance graphics, which according to Spectra offers up to 65% higher multi-thread computing performance and up to 70% faster graphics performance compared to the previous generation, ensure high-performance graphics. It enables the connection of three independent displays in 4K quality via LVDS, HDMI and DP port.
Functions such as Wi-Fi or Bluetooth can be upgraded with the help of three M.2 slots and an mPCIe slot. External peripherals can be connected via six USB 3.2 Gen 2 and two USB 2.0 ports. Two Gigabit Ethernet ports are also available for wired network connections. An operating temperature of 0°C to 60°C supports use in industrial environments.
QNAP
Virtualization of network functions
QNAP has introduced the new QuCPE-303x Network Virtualization Premise Equipment. It combines network function virtualization, QuWAN SD-WAN and the AMIZ cloud management platform with Intel hardware network acceleration technologies.
Compmall
Embedded PC DV-1000
The DV-1000 embedded PC from Compmall is fanless, robust and compact. With a mounting kit, the PC can be attached to the DIN rail to enable applications in factory automation, logistics for controlling autonomous mobile robots or image processing
Spectra
Second source for remote Profinet I/O
The Profinet Remote I/O of the PFN-2000 series from Spectra are suitable for Profinet I/O applications in which, for example, a Siemens S7 or compatible PLC acts as the central control unit and in which other analog and digital signals are to be...
Spectra
Scalable for BV applications
Industrial image processing ranges from simple applications in environmental perception such as positioning, measuring, identifying and sorting objects to more complex image processing-controlled automation functions.
