Aetina
Edge AI applications simplified
Aetina's DeviceEdge Mini edge AI-enabled computer extends the company's 'DeviceEdge' platform range.
Edge AI-enabled computer DeviceEdge Mini from Aetina
© Aetina
Aetina's platform series offers multiple options and SKUs to help developers create and deploy AI applications for mass production. Utilizing the 260-pin SO-DIMM connector, the fixed mechanism can be flexibly embedded into various Nvidia Jetson SOMs such as Jetson Xavier NX, Jetson Nano and Jetson TX2 NX. In addition, the series can be expanded to a 128 Gbyte NVMe SSD to run edge computing applications that enable data transfer 25 times faster than SATA SSD.
The M1 mini series supports Powered Devices (PD), which can receive power from Ethernet devices without an adapter. In contrast, the Mini Series M2 supports two Power Sourcing Equipment (PSE) formats, which ensure power supply via Ethernet cables. Two PoE cameras enable transmission up to a distance of 100 m. And the Mini Series M3 can be used with up to eight compressed cameras.
Siemens
AI classification for safety
Artificial intelligence is seen as a solution to current challenges in various areas of life. Politicians are promoting AI, but would like to assess the consequences of the technology and regulate it if necessary. The use of AI for security tasks is...
DFKI
Research building opened in Bremen
One of the most important research institutions in Germany in the field of artificial intelligence has opened a new building in Bremen. The DFKI intends to use the extension to advance research into future topics, according to a press release.
