Box PCs
Quelle: Axiomtek | Lukas Dehling,
Control three independent displays simultaneously
Axiomtek is expanding its range of modular box and panel PCs with the eBOX671-855-FL, a fanless AOI system. The box PC can be equipped with either an Intel Core i7/i5/i3 or a fourth-generation Celeron processor with LGA1150 socket (Haswell/Haswell Refresh) and up to 16 GB DDR3-1333/1600 MHz memory.
© Axiomtek Germany
In addition to the 4-port Gigabit PoE, the additional 2-port Gigabit Ethernet and the six USB 3.0 ports, the eBOX671-855-FL offers one HDMI, DVI-I and display port each, which can simultaneously control the three independent displays. Thanks to the extended temperature range of -20 °C to 50 °C and the many connection options, the box PC is predestined for all conceivable areas of industrial automation technology, optical inspection or digital advertising, according to the manufacturer.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
