Box PCs
Quelle: TL Electronic | Inka Krischke,
Cable-free and fanless inside
The IKMH100 box industrial PC from TL Electronic with a seventh-generation Core i5 processor (Kaby Lake) offers a maintenance-friendly hardware architecture.
© TL Electronic
The cable-free and fanless design inside ensures reliability and secure availability, and users can access the solid state disks or hard disks from the front and without tools. The Core i5 7200U CPU with 3 Mbyte smart cache and 2 × 2.5 GHz clock speed at only 15 W power dissipation (TDP) works at the core of the embedded PC. The processor uses the integrated Speed Shift technology. In favor of efficiency, the operating system leaves part of the processor control to the processor. This results in an increase in performance with lower power consumption, less waste heat and therefore optimized system efficiency. The computing power is supported by the main memory of 16 Gbyte DDR4 SO-DIMM and the integrated solid-state disk from 64 Gbyte. The CPU-internal system-on-chip graphics supports displays with up to 4096× 2304 pixels. The industrial box PC can be mounted either using the VESA mounting holes or the wall mounting brackets.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
