Industrial PCs
Quelle: Efco Electronics | Lukas Dehling,
As big as a smartphone
Under the name SmartSL U7-100, Efco offers a range of fanless industrial computers that are designed to offer flexibility in terms of processor performance and Qseven features thanks to the use of Qseven CPU modules.
© Efco Electronics
The interface configuration can also be individually tailored to the user's requirements thanks to Qseven module technology. The devices are based on Intel's Bay Trail architecture. 1× USB 3.0/2.0, 2× USB 2.0, 1× RS232, 1× DP, 2× Gigabit Ethernet and 1× audio (line-out)/MIC are installed as standard. There are also two slots for full-size PCI Express mini cards. With dimensions of 160 mm × 88 mm × 19 mm, the industrial computers are about the size of a smartphone, making them a compact solution for factory automation, machine control and embedded applications. The devices require a supply voltage between 9 and 32 V(DC) ±5 % and can be used at temperatures from 0 to +70 °C. They bear the CE mark. They carry the CE mark and comply with FCC regulations (Class A). An operating system (Microsoft Windows 8/Windows 8 embedded, Windows 7/Windows 7 Embedded Compact or Linux) can be installed as an option.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
