Box PCs
Quelle: Plug-In Electronic | Lukas Dehling,
4K resolution possible
The Embedded Box PC series BP-IVH9200MXC from Plug-In is designed for the extended temperature range between -40 and +75 °C. The LGA1151 socket supports the Intel Core Kaby Lake processors ...
© Plug-In Electronic
as well as the Intel Xeon/Core processors with the Intel C236 chipset and dual-channel DDR4 2133 MHz ECC memory - expandable up to 32 GB. The Intel HD Graphics 530 processor supports DirectX 12, OpenGL 4.4 and OpenCL 2.0 API. The fanless embedded system also has onboard DVI-I, DVI-D and DisplayPort display interfaces for Ultra HD 4K resolution. A 6 to 36 V power supply with 80 V overvoltage protection and EN 50155 and EN 50121-3-2 certifications are designed to ensure smooth operation. The system series also has features such as 6× GigE LAN ports with 4× IEEE 802.3at PoE+ without additional power connections, 4× front-access 2.5-inch SSD/HDD trays with RAID-0/1/5/10 data protection, 3× SIM card slots for 3G/4G/LTE/WiFi/GPRS/UMTS, 1× front-access CFast slot. It also offers 8× USB 3.0, 4× COM-RS232/422/485 and 4× SATA III (6Gbps) ports.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
