R3 Solutions
Summer release for Ethernet Bridge
R3 Solutions publishes the 'Summer Release' of the software for the Wireless Ethernet Bridge with new and improved functions. The release and the parallel introduction of 'Bridge E' marks the start of a six-month software release cycle.
© R3 Solutions
In conjunction with the current version of the Echoring Ethernet Bridge, which will be called 'Bridge E' in future, R3 Solutions is embarking on "a new era": in future, there will be two major software releases for R3 products per year: a 'Summer Release' with new tested functions and a 'Winter Release' aimed at system maintenance. The most visible change in the summer release is the new control and configuration interface 'Plant UI', which allows industrial users to centrally manage even highly scaled Bridge-E installations. The Plant User Interface is part of the now Windows-based Config Server, which provides configuration, update handling and device control. The previously required dedicated Config server as additional hardware is therefore obsolete.
Another new feature is the so-called 'Echoring Runtime Control Interface (ERCI)'. The control interface is available directly in the bridge and via the Plant UI. It enables the status of the devices to be recorded using scripts and their functions to be adjusted during operation using control commands.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
Wireless
In real time without cables
Real-time communication without cables! - In order to increase the flexibility of production plants, this is a much cherished wish. But where exactly is this scenario still failing? What are the possible solutions? And what role do OPC UA and TSN...
Follow-up with Mathias Bohge
5G in the factory
Incorporating the needs of the industry - the automation experts failed to do this with the European standard for wireless communication. A dilemma that should not happen again with the fifth generation of mobile communications, 5G. A major task for...
