Sigmatek
Andrea Gillhuber,
Flexible analog mix module
The analog mix module 'AM 821' from Sigmatek's S-DIAS series has eight analog differential inputs with 16-bit resolution and two analog outputs.
© Sigmatek
The inputs and outputs support the signal ranges 0-20 mA, 4-20 mA and 0-10 V and can be individually configured between current and voltage signals. The measuring rate is ≥ 500 µs for all channels.
Features include integrated short-circuit detection, software-configurable input filters to reduce signal noise and status LEDs for channel-specific diagnostics. An 'Eplan macro' is available for control cabinet planning. The DIN rail module measures 12.5 mm × 104.2 mm × 72 mm (W × H × D) and is suitable for applications with mixed sensor requirements, for example in measurement technology, in laboratory and analysis devices as well as in test and inspection benches.
