SSVIoT building blocks for edge gateway applications
SSV believes that the development of an industrial IoT application requires solid planning and a DevOps process chain with a development process that covers the entire life cycle of the application.
5 of 6
© Amperesoft
With version 2023.1 of Amperesoft's ToolSystem, users benefit from significant time savings when planning and calculating a system and creating suitable parts lists thanks to integrated processes and a link to external sources, according to the provider. The system combines software modules that support the engineering process from planning to installation. This includes the ToolDataManager for searching for existing projects and data. This module has been further developed in the current version. A new addition is the option of linking external sources to the ToolSystem, which simplifies the maintenance of material data. Material data can be kept up to date using a master database specified by the user. The ToolDataManager checks and corrects the information by comparing the existing data with that of the master database. If differences occur, the incorrect data is automatically replaced by the current values.
SPS 2022: Hall 6, Stand 116
5 of 6
