LappDecentralized switches with IP67 protection
Lapp is launching two switches for use outside the control cabinet: thanks to IP67 classification, the Etherline Access PN IP67 Profinet switch and the Etherline Access U IP67 unmanaged industrial Ethernet switch are suitable for use directly in the field.
bMotion is the name of the newly developed drive platform from Bühler Motor. It consists of DC motors, gearboxes, brakes and encoders. Specific, pre-validated combinations are already available for special market requirements. Users also benefit from defined lead times for sample, pre-series and series parts. On the basis of the drive platform, the drive systems can already be largely adapted to customer requirements. In this way, user-specific developments can largely be replaced by configure-to-order. Despite modularity and standardization, important parameters such as specific shaft ends, winding adaptations or special output bodies such as pinions or pulleys can be individually adapted. In addition, various interference suppression variants are provided as well as temperature sensors for condition monitoring and predictive maintenance.
SPS 2022: Hall 1, Stand 230
