port
For Profinet, EthernetIP and Ethercat
Renesas has launched the 'R-IN32M3 Modules for Multi-Protocol Support', which offer multi-protocol support on board and support Profinet CC-B (including MRP), EthernetIP (including DLR) and Ethercat.
© port
The ICC Engineering Tool from port supports the module or the user with the configuration on the application side. ICC (Industrial Communication Creator) is a convenient tool for configuration and object dictionary management. The tool can be used to configure individual functionalities in conjunction with the on-board protocols such as Profinet/EthernetIP and Ethercat stacks.
In addition to the settings for the 'Resource Management', the 'Device Description', the setting of the module and slot parameters, the 'Driver Settings' and the 'Parameters/Assemblies/Connections', the GSDML (Profinet), EDS (EthernetIP), ESI (Ethercat) files are generated. The tool is available for Linux and Windows.
Ethernet-APL
The standard is
Standardization work has been underway since 2015 and the intrinsically safe physical layer designed for 2-wire cables called Ethernet-APL is now available; the first products are ready for the market.
TSN
Arrive in reality!
Time Sensitive Networking has firmly established itself in the vocabulary of the automation industry. All well-known suppliers have started activities to evaluate or even introduce TSN. But where exactly are the goals for the use of TSN and what is...
QNAP Systems
Next-Generation Switches
QNAP has announced the new generation of its QSW-M2130 L2 Web-Managed Switch series. It is available in two models—the standard model “QSW-M2130-4C2S24T” and the PoE++-capable model “QSW-M2130P-2C2S26T.”
