1 of 11
News about sensors
© PCB Synotech
Synotech has added the model M607M83 to the robust ICP/IEPE vibration sensor models 'M607A11 Swiveler' and 'M607A61 Spindler'. Its internal sensor electronics are designed in 3-wire technology, enabling it to be supplied with a direct voltage of 3 to 12 V(DC). The sensor measures in the frequency range from 1.5 to 10,000 Hz with a sensitivity of 100 mV/g. It is supplied with a 1-point calibration at 100 Hz. The 'Swiveler' technology facilitates the installation of the industrial vibration sensor with IP68 protection: there is a union nut above the sensor base which is screwed onto the mounting bolt. The 3 m long integrated connection cable does not have to be rotated around the sensor axis, but can be freely aligned.
1 of 11
