1 of 7
New products from Jumo at the Hannover Messe 2019
Jumo, sensor, plastic, plastoSENS, motor winding
© Jumo
In the fall of 2017, Jumo presented 'Plastosens' technology, an innovative process for the production of temperature measurement technology made from high-performance plastics. 'Plastosens T' temperature sensors are stress and vibration-resistant as well as waterproof. They also offer freedom of form and adapt to the respective installation situation. In addition to four standard products for different areas of application, there are now also special versions, for example a special design for motor windings: This 'Plastosens T' sensor can be used in temperature ranges between -40 and +200 °C, can be easily glued into the motor winding and has a pulse voltage resistance of up to 8 kV. It is also shock-resistant up to over 100 g and can be used as a standard-compliant sensor in accordance with DIN EN 61800-5-1:11-2017.
1 of 7
