ifm
Peter Stiefenhöfer | Inka Krischke,
Pallets automatically recognized
How can the productivity of logistics processes be increased and the effectiveness of Automated Guided Vehicles improved? One promising approach is a system for automated pallet recognition based on time-of-flight cameras.
© ifm
Forklift trucks and pallet trucks are part of everyday life in the intralogistics of many companies when loading and unloading trucks with pallets. The optimization of warehouses and many storage and retrieval processes are hardly imaginable without these powerhouses. As a rule, such vehicles are still operated manually. With a system for automated pallet recognition based on time-of-flight cameras, ifm electronic aims to make such processes more efficient, reduce the error rate compared to manual operation and improve the overall equipment effectiveness of companies. The aim is to increase productivity in logistics processes and improve the effectiveness of automated guided vehicles (AGVs).
Some of these autonomous vehicles are already equipped with systems that allow them to recognize the pockets in which the forks of the transport vehicles need to be positioned. Laser lines are usually used in these cases, but they require a relatively long time for reliable position detection. Developers at ifm robotics have therefore taken a closer look at this task and created a system called 'Pallet Detection System', or 'PDS' for short, based on the company's own time-of-flight cameras.
Time-of-flight as a basis
PDS' is based on the time-of-flight cameras from ifm's O3D series. They work according to the time-of-flight method and use the phase shift of several light pulses that are emitted and reflected by objects. By measuring the time delay between the emitted light pulse and the reflected light pulse detected by a sensor, the distance from each reflecting object point to the sensor can be determined relatively precisely. With this technology, it is therefore possible to measure the distances of each individual object point to the sensor and thus take three-dimensional images of objects.
The pallet detection system identifies the exact position of all standard pallets with two pockets. The system is based on time-of-flight cameras from ifm's O3D series, which are typically installed slightly above and between the forks of the vehicles.
© ifm
The developers used this property for the pallet recognition system: they installed a ToF camera slightly above and between the forks of an autonomous forklift truck, which moves to a distance of between one and two meters from the next pallet to be gripped during operation. Using the triggers, the ToF camera records a complete 3D point cloud of the pallet, which is then filtered using the 'PDS' algorithm to eliminate noisy or unnecessary pixels. As a result, the system outputs the pallet's degrees-of-freedom pose, which displays the exact pallet coordinates in the x, y and z directions as well as any rotations around the vertical axis or horizontal tilts. The 'PDS' communicates this data by wire via an Ethernet interface or a CAN field bus to the vehicle's control system, which then ensures that the load is picked up correctly.
Successful in use
Autonomous forklift trucks equipped with the PDS system drive up to a distance of between 1 and 2 m to the next pallet to be picked up before the ToF camera takes a 3D image of the pallet.
© ifm
The x, y and z positions of the two pockets are also calculated in detail to ensure that the pallet is correctly picked up by the transport system. This data is output with a confidence factor that represents the deviation from an ideal pallet. The user can thus define limit values for reliable identification and determine the conditions under which manual intervention is required, depending on their individual requirements. With evaluation times of usually less than 1 second, the system is considerably faster than comparable systems and meets the usual requirements of warehouse processes in most fields of application.
This task is by no means trivial: in warehouses, situations are often difficult to predict, for example due to pallets that have been in use for a long time and therefore no longer correspond 100% to the ideal geometric condition, or due to stored goods that are slightly displaced or twisted in their location. Films that are often used to wrap pallets and the goods stored on them for protection can also come loose, making it difficult to identify the correct position.
Sebastian Vögele is a member of the Customer Solutions team at ifm electronic
© ifm
Ifm's target customers for 'PDS' are the manufacturers of automated guided vehicles, who are to integrate the system into their vehicles. The company's expertise covers both the hardware in the form of the time-of-flight cameras and the software part, which is used to evaluate the measured results.
The integration of 'PDS' into the vehicles is the responsibility of the AGV manufacturer or a system integrator.
The system has already proven its suitability in practical use several times and is in operation at numerous customers worldwide. One major customer in the USA, for example, already has over 300 self-driving robots in operation using the system. There, it also checks planned pallet storage positions and, with its high repeat accuracy and low downtime, ensures that the set targets are achieved: The number of errors compared to manual operation has been significantly reduced.
Allied Vision
Four new USB camera models
Allied Vision has added a total of four Alvium cameras with a USB3 Vision interface to the '1800' series. All models feature a 2nd generation Sony CMOS sensor, either with Pregius global shutter technology or with rolling shutter.
ifm
Digital retrofit
The E43406 and E43410 data splitters from ifm can be used to allow the additional information generated by today's sensors to be used by PLCs.
Optometron
Space for microscopy and analysis
In quality control, space is often limited, so there is little room for microscope equipment. With the Doku-Kit3, Optometron offers a handy camera-monitor unit that enables self-sufficient microscopy and analysis without a PC.
Captron
Working without 'pressure'
Safety switches based on capacitive buttons enable fatigue-free working. They can also be part of two-hand controls that prevent incorrect or inattentive operation with just one hand or another part of the body.
Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use...
