Agricultural robots
autoVimation supports ETH Zurich project
The aim of the 'Rowesys' - Robotic Weeding System - project at ETH Zurich is to develop a sustainable alternative to the use of herbicides in agriculture based on mechanical weeding. autoVimation is supporting the project as a sponsor.
The 'Rowesys' agricultural robot developed at ETH Zurich is equipped with a protective camera housing from autoVimation.
© Steffen Imanuel Denker
ETH Zurich's focus project impressively demonstrates how damage to people and the environment can be minimized with the help of digitalization and smart technology. Ten ETH students have been working on the development of the agricultural robot 'Rowesys' since last September with the support of eight expert coaches and sponsors. The functional prototype was designed for sugar beet fields because they require a relatively high use of herbicides.
The agricultural robot pulls small plows through the soil, which pull the roots of the weeds from the ground to the surface and thus dry them out. The autonomous system uses an Intel 'RealSense' camera to detect tracks and the end of the field, at which point it automatically switches to the next uncultivated row.
To protect the sensitive camera system, autoVimation supplied a suitable protective housing and a swivel and tilt mounting device.
autoVimation
Precisely align the protective housing
The positioning system is a compact solution for the precise alignment of protective camera housings. The core of the modular system consists of fine positioning axes with 150 mm stroke, which ensure high adjustment accuracy with their hand-cranked...
ABB
'Second life' for used robots
Instead of scrapping inactive or older robots and leaving them unused in the production hall, existing customers can sell them to ABB via a buy-back service. The robots are reconditioned there.
OnRobot
Grasp like a gecko
With the Single Pad Gecko gripper, OnRobot is launching a compact version of the 'Gecko' gripper, which is particularly space-saving and lightweight. It is designed for three different payloads.
Exner
Robot programs itself
Robot welding processes have been unprofitable in steel construction to date. This has changed with a solution in which the robot programs itself and then welds each component immediately.
