Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely detect the current orientation - i.e. the inclination or position (360°) - and the speed in a rotating application at the same time.
The sensor is mounted in the rotating part and does not have to be positioned centrally on the axis of rotation. The sensors used for position (accelerometer) and speed (gyroscope) are MEMS-based.
The sensor is optimized for non-reversing operation. It transmits its values to the controller via CANopen or Profinet (also Profisafe - PLd). The direction of rotation, zero point and distance to the rotary axis can be parameterized; a special version also detects the distance to the rotary axis automatically.
In principle, the function corresponds to that of a rotary encoder for position and speed. Special filter measures suppress interfering accelerations.
