Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
7 of 11
6 Zander Aachen
© Zander Aachen
Zander Aachen is expanding its range of safe mini time controllers 'SCB'. Input and output delay as well as free parameterization of the inputs and outputs are already available. The time control offers precisely parameterizable time ranges from 0.1 s to 99 h. Typical applications include bypass pressure monitors, filtering short-term fluctuations and monitoring boiler flushing times.
The logic of the two signal outputs is adapted in the new SCB version: In addition to the non-delayed and delayed safe outputs, one signaling output each is available with the corresponding inverted signals. This makes it easier to retrofit existing systems, where previous relay solutions with a normally closed/ normally open combination can be replaced by an 'SCB' variant.
The delayed reset functionality has also been added. This prevents accidental resetting of safety systems if someone is still in the danger zone of the machine. One or more buttons must be pressed for a specified maximum time to reset the system.
For tuning.
7 of 11
