Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
BMR elektrischer & elektronischer Gerätebau manufactures frequency inverters for high-speed asynchronous (AC) and synchronous (BLDC) spindles for milling, grinding, drilling and dressing in the power range from 150 VA to 3.6 kVA.
Key features include high acceleration capacity, short braking ramps, a freely programmable I/O configuration that allows flexibility in machine integration and freely available configuration software. With DressView, the company's proprietary method for gate detection and dressing control, the spindle becomes a sensor:
It determines data that enables the control system to react immediately in real-time evaluation. Among other things, the system detects the spindle status (bearing quality), tool fatigue or tool breakage.
The measured values enable adaptive feed control, stabilize the production process and reduce the risk of production downtime.
'DressView-Lite' is an embedded solution of the system without a display, which is integrated directly into the frequency inverter. The measured values are either output as analog values or can be continuously determined by the control system via an interface.
A special industrial gateway, the 'SFU-Communicator', connects all of the company's inverters with the higher-level machine control systems.
