Products of the year 2020/2021Readers' choice: Who are your favorites?
Smart, innovative, trend-setting - that's what the automation industry was like again this year! We have nominated 96 products in twelve categories and put them forward for your vote as "Products of the Year". Which are the most innovative and useful products for you?
Weidmüller 's Advanced Line managed switches support protocols such as STP/RSTP or SNMP and can be configured intuitively via a browser-based web interface. With model variants for Fast Ethernet, Gigabit and PoE as well as 5 to 24 ports, they ensure a high degree of flexibility. The devices support a combination of ring and line redundancy, whereby several Ethernet switches are linked in a line network.
By configuring the head and tail switches - at the outer ends of the chain - both ends of the chain are integrated into the network.
With the ring and line redundancy method, administrators can create redundant topologies in each network segment.
If a network segment fails, the network restores itself in just 30 ms for up to 250 switches by activating a back-up path. To ensure smooth operation even in the event of a fault, there is an external backup and restore module that is used to save the configuration of the device. Depending on the version, the switches are equipped with a variety of combinable interfaces - copper or fiber optic.
The switches are available in 'Full Managed' and 'Lite Managed' versions.
